Ruckus T610
Product Detail
The T610 delivers blazingly fast connectivity for high-density outdoor deployments, with combined radio data rates of 2.5Gbps and the density-handling ability to match. Patented BeamFlex+ technology rejects interference amd improves signal quality for any device, anywhere. Included MU-MIMO technology maximizes network efficiency, reducing bottlenecks and enhancing user experience. Smart Mesh accelerates time-to-deployment and eliminates the cost associated with Running Ethernet cabling between multiple access points in the network. The T610 can be used with any Ruckus control and management platform - appliance, virtual or cloud-managed. That means as your business needs change, your architecture - and your APs - can change with you.
The T610 is designed for high-density deployments in which dozens of clients need guaranteed high throughput. Smart Cities providing city wide wireless connectivity for: municipal Wi-Fi, untilities and smart sensors for IoT applications are ideal use cases for the T610. The T610 is for customers that want premium wireless performance and don't have specialized backhaul interface needs (like fiber or coaxial cable).
- Model Name:
- T610
- Product Family:
- EOL RUCKUS Products
- Recommended Software:
- Stability Release:
- Technology Release:
Please Wait...
Please Wait...
ID | Title | Version | Release Date | Edit Date |
20210129 | AP / ZD CLI Passphrase Vulnerability | 1.0 | January 29, 2021 | January 29, 2021 |
20210511 | RUCKUS AP Aggregation And Fragmentation Attacks Vulnerability (aka “FragAttacks”) | 1.1 | May 11, 2021 | October 15, 2021 |
20230208 | CVE-2023-25717: RUCKUS AP Web Vulnerability (RCE/CSRF) | 1.2 | February 08, 2023 | May 18, 2023 |
20230731 | RUCKUS Unleashed Authenticated Remote Command Execution Vulnerability | 1.1 | July 31, 2023 | August 01, 2023 |
20231128 | CVE-2023-49225: RUCKUS AP Stored Cross-Site Scripting Vulnerability | 1.0 | November 29, 2023 | November 29, 2023 |
20240925 | RUCKUS AP Remote Code Execution Vulnerability | 1.2 | October 04, 2024 | October 11, 2024 |
20250122 | Security Advisory 20250122: Multiple vulnerabilities in RUCKUS Unleashed and ZoneDirector | 1.0 | January 27, 2025 | January 27, 2025 |
Technical Support Bulletins
TSB-2024-003 | TSB-2024-003_Wave_2_APs_stuck_in_Constant_Reboot | 1.0 | 2024-05-29 | 2024-05-29 |
TSB-2025-002 | TSB 2025-002 - 11ac/Wave-2 R1 Cloud APs random disconnections reported in version 6.2.4.103.260 and earlier release | 1.0 | 2025-04-14 | 2025-04-14 |
