RUCKUS H350
  • RUCKUS H350 Access Point - Bottom
  • RUCKUS H350 Access Point - Top
Product Detail
The RUCKUS H350 is a Wi-Fi 6 (802.11ax)  Wi-Fi access point with integrated switch in a wall-plate form factor.
H350 features Ruckus' patented BeamFlex + adaptive antenna technology to deliver high-speed 802.11ax WiFi in a low-profile design that can be discretely installed over a standard electrical junction box.  H350 allows a range of wired & wireless services to be delivered in hotel guest rooms, student residences, and multi-dwelling units with just a single cable pull per room and eliminates the need for additional switches and power supplies.
Equipped with two Ethernet ports for in-room access, the RUCKUS H350 can be used to connect wired network devices such as IPtv set top boxes while simultaneously providing dual band Wi-Fi 6 WLAN coverage and BLE or Zigbee coverage with an IoT Radio.  The H350 may be powered via standard PoE or a DC power adapter.  The H350 can be managed by SmartZone, ZoneDirector, Cloud or Unleashed management platforms.
Model Name:
H350
Product Family:
RUCKUS Indoor APs
Recommended Software:
Stability Release:
Base release:
vSZ-D 6.1.2 (LT-GD Patch 6) Software Release (.ximg image)
Technology Release:
Base release:
vSZ 7.2.0 (LT-GA) Software Release (.ximg image)
Patches:
Ruckus SmartZone (LT-GA) AP 7.2.0 Patch1 Software Release
Documents
Downloads
KB Articles
Forum Topics
Security Bulletins
Support Bulletins
Advanced Search
Working...Please wait
This is here to prevent you from accidentally submitting twice.
The page will automatically refresh.
Alert!!
Close
