RUCKUS ICX 7650 Campus Switches
  • Ruckus ICX 7650
    Ruckus ICX 7650
Product Detail
Ruckus ICX 7650 Campus Switch
The Ruckus®  ICX®  7650 Switch is designed to meet the new challenges of the multigigabit wireless era. It delivers non-blocking performance, high availability, and scalability with Multigigabit Ethernet access (2.5/5/10GbE), high PoE output with 802.3bt** support as well as 10 Gigabit Ethernet Aggregation and 40/100GbE uplink options.
The ICX 7650 is an ideal solution for future proof campus edge deployment as an underlay to support the most demanding next generation wireless infrastructure. Additionally the fiber version of the switch delivers a highly cost effective medium density 1/10GbE aggregation solution with 24 SFP & 24SPF+ ports and 40/100GbE uplinks.
The ICX 7650 supports Ruckus Campus Fabric* as both a Port Extender (PE) and a Control Bridge (CB) delivering unmatched flexibility, scalability and simplified management for campus network deployments.
Model Name:
ICX-7650
Product Family:
RUCKUS ICX Switches
Recommended Software:
Stability Release:
Patches:
RUCKUS ICX FastIron 10.0.10g_cd5 (GA) Software Release (.zip)
Notes:
Ruckus ICX software currently has two release types; Stability and Technology.
We recommend all customers utilize the Stability Release if it contains all needed features for your network. A Technology Release should only be used if your network requires new features not available in the Stability Release.
RUCKUS One (cloud) users: Please check the 'Version Management' page within your RUCKUS One GUI for your recommendation
Documents
Downloads
KB Articles
Forum Topics
Security Bulletins
Support Bulletins
Advanced Search
Working...Please wait
This is here to prevent you from accidentally submitting twice.
The page will automatically refresh.
Alert!!
Close
