SmartZone 100-D (SZ100-D)
Product Detail
The SmartZone™ Data Plane appliance (SZ100-D) is a wireless LAN data plane appliance, that comes in physical form factor as a family of two products, first with 1Gbps and second with 10Gbps throughput support. Made to work seamlessly with Ruckus SmartZone network controllers, the SmartZone Data Plane appliance enables secure tunneled WLANs from Ruckus APs while minimizing CAPEX spending and maximizing Wi-Fi deployment flexibility and scale.
SZ100-D appliance benefits businesses that have leaner IT departments with limited virtualization expertise or that wish to further simplify deployments. Operators, ISPs and large enterprises can deploy the SZ100-D in a centralized data center with SmartZone network controllers, or at specific venues in a distributed topology. In addition, organizations have the flexibility to deploy SZ100-D at each of the tenant locations based on their requirements.
The Data Plane appliance brings multiple high value features, such as:
- High performance DHCP-server
- NAT (Network Address Translation)
- L3 Roaming
- Flexi-VPN
- Model Name:
- SZ100-D
- Product Family:
- EOL RUCKUS Products
- Recommended Software:
- Stability Release:
Disable AP radio | vSZ | SmartZone
How to disable a specific radio on an AP
How to login to SmartZone managed APs?
You can login to SmartZone managed APs directly, with Zone setup field info, or with cluster username password on SCG/vSZ-H APs, or defaults on Staging zone APs.
What are the order of steps in SmartZone AP Zone upgrades?
APs exchange information with SmartZone, triggering firmware download, reboot, configuration.
SmartZone node not able to join the Cluster
Common causes of node join failures are Misconfiguration of Network Settings, Firmware Version Mismatch, Form-Factor Compatibility, Interface Configuration Matching, IP Version... (continued)
How to disable SmartSelect on standalone AP
This article explains about disabling auto channel assignment by the AP in standalone mode
Steps to Replace Standby ZD in Smart Redundancy Setup
Steps involved in replacing defective/failed Standby ZD in Smart Redundancy Setup
Cannot create tunneled SSID on legacy (3.6.2) zone on SmartZone 6.1.2.0.487
Cannot create tunneled SSID on a zone that has version 3.6.2 AP firmware, while controller is version 6.1.2.0.487
SmartZone Ports to be open on a Firewall w/NAT
What ports/protocols need to be open to permit AP to SmartZone controller communication, and if including NAT?
TACACS+ Connection Failing from SmartZone(SZ)
SmartZone connection fails due to outbound firewall
Steps to ensure AP stability
This article talks about what can be done to ensure AP stability.
Do we have any Setup info for Wi-Fi Calling in SmartZone 5.0?
The attached guide describes Wi-Fi Calling and requirements, with SZ 5.0 controller side configuration example.
What tools can I use to test API’s on SmartZone platform
This article describes 2 software tools that can be used to test API’s on SmartZone platform
SmartZone 802.1x-MAC option description
Description of the operation of 802.1x-MAC option available for WLAN configuration on SZ controller platform
SmartZone Report Filename format details
SmartZone report filenames include a string of digits after the text.
This article outlines the details of these digits.
Disable Weak Ciphers on SmartZone
Article explains about weak ciphers on SmartZone and whether it can be disable or not
SmartZone UDP:3799 port for AAA CoA and DM
UDP port 3799 is necessary for RADIUS CoA and DM messages and are ONLY supported in Proxy Mode.
Visualize Airtime Detail in SmartZone 3.6 / 5.0
New SmartZone feature provides graphical representation of Airtime Utilization details.
Inconsistencies with "AP Connection status" on SmartZone 5.1.0 web GUI
This article explains the solution for the inconsistencies seen with "AP Connection status" on SmartZone 5.1.0.496 web GUI
How to disable Smartcast?
Customer wants to disable Smartcast for testing of voice streaming application without prioritization
What is the first SmartZone firmware to support T310d Outdoor AP?
We released an AP patch bundle with T310d AP support on 3.6 GA. The T310 series is supported natively in SZ 3.6.1 and later.
Enabling smart-roam on SmartZone controller
How to enable smart-roam on SmartZone controller via CLI.
How to set Static route for SCG
Ruckus SmartCell Gateway has both Data plane and control plane for routing configuration. This will tell how to set route in both control and Data plane
How to migrate Access Point(AP) from RUCKUS One(R1) to RUCKUS SmartZone(SZ)
This guide provides a step-by-step process to migrate an AP from R1 to SZ. The process involves factory resetting the AP, upgrading it to a solo image, and then joining it to vSZ/SZ.
How to troubleshoot Ruckus SmartZone Cluster Upgrade Issue?
This document provides a comprehensive guide for Ruckus SmartZone controller Cluster Upgrade Issues. It includes necessary steps, troubleshooting tips, and resolution methods.
How to Configure SmartZone to support Google Orion wifi
This document outlines how to configure and troubleshoot SmartZone 5.2.1 to support Google Orion hot spot 2.0 wifi.
How does failover to a different controller work on SmartZone APs?
This article explains failover process on SmartZone APs.
Differences between ZoneDirector (ZoneFlex ZD) and SZ100 / vSZ / SCG200 (SmartZone)
Product AP capacity / authentication / feature / function differences between ZoneDirector (9.13) and SmartZone (3.4) controller platforms.
What is SmartZone/vSZ Entitlement File and How to Download it?
Steps to download the Support and License File for the SmartZone/vSZ controllers
New data plane does not show up on the SmartZone GUI for approval
A new data plane that is trying to connect to a SmartZone is not showing up on the SmartZone GUI for approval. The log files indicate that the SZ's web server returns a Bad Request... (continued)
How to gracefully shutdown the Virtual SmartZone Controller
This article explains the step by step process to gracefully shutdown the Virtual SmartZone (vSZ) which is often needed for the maintenance windows or to make any resource level changes... (continued)
Is there a mobile app to manage RUCKUS SmartZone(SZ)
Availability of mobile app support for RUCKUS SmartZone controllers. While administrators seek a dedicated mobile app to manage and control SmartZone devices, currently, no official app... (continued)
Preparing ICX Devices to be Managed by SmartZone
How to enable Smart RF?
How to Troubleshoot RUCKUS SmartZone Dataplane / Virtual Dataplane client connectivity issue?
This document provides a comprehensive guide for SZ-Dataplane and vSZ-Dataplance client connectivity Issues. It includes necessary steps, troubleshooting tips, and resolution methods.
Using Google OAuth for Zero-IT provisioning in SmartZone setup
This article contains a document on how to use Google OAuth service to provide Zero-IT based secure access to wireless users. Any user with a GMAIL address can log into the onboarding... (continued)
SmartZone OS equivalent for remote ap cli -A command like in ZD
How to run AP CLI commands from SCG/vSZ/SZ1xx/SZ300 running Smartzone OS
Changing static IP of the ZDs when smart redundancy is enabled
This article explains how to change Static IP of primary ZD, Secondary ZD and management interface when there are 2 ZDs on smart redundancy.
What is the Latency for ZD Smart Redundancy
ZDs use encrypted heartbeats to maintain Smart Redundancy
Disable Smart-redundancy on ZD
This article helps in disabling the smart-redundancy on the ZD
Can two different RUCKUS SmartZone (SZ) models use the same Cluster name in the same network?
Using the same cluster name for two different SZ models in the same network is not allowed. This will cause the existing cluster to display the error: “Unable to retrieve the cluster... (continued)
How many ICX switches can we connect to a SmartZone 5.0 Cluster?
See details in the Release Notes and Getting Started Guide for ICX switch count per SZ type cluster.
SmartZone Fault Tolerance and Clustering explained
SZ clusters replicate DB info across members and there are methods to prevent loss if a member node becomes unavailable.
Migration of Configuration from One SmartZone platform to other
Restoration of Configuration backup is possible only between same platform of SmartZone. The only exception is that SZ100 configuration backup can be used to restore on an SZ144 (but not vice-versa)
Converting SmartZone AP to Ruckus Cloud Wi-Fi and vice versa
The attached guide will walk thru the steps necessary to convert SmartZone controller managed APs to Ruckus Cloud Wi-Fi, and vice versa.
R710 AP cannot connect after upgrading controller to SmartZone v3.1.1
AP certificate issues may prevent R710 from connecting to vSZ/SCG/SZ-100, or cause client webauth/guest pass authentication failure.
How to add additional SSH port in RUCKUS SmartZone(SZ)
Article talks about how to configure an additional port for SSH access, while default port remains 22 for SZ and AP/Switch/Dataplane communication.
File upload through the SmartZone ChatBot Interface isn't working
When trying to upload the logs to through the ChatBot interface of the SmartZone.
Upgrade compatibility from SmartZone 6.1.2 Patch-3 to SZ 7.0.0
This Article explains the upgrade limitation from SZ 6.1.2 Patch-3 to SZ 7.0.0 Release
Terrapin Attack Vulnerability CVE-2023-48795 on RUCKUS SmartZone(SZ)
CVE-2023-48795 Terrapin Attack affects OpenSSH v9.5 and earlier versions. Vulnerability allows attacker with local network access to manipulate information during the SSH connection’s... (continued)
AP Heartbeat Timers in Smartzone: Behaviour, Configuration, FAQ's
The article provides information on the AP heartbeat function within SZ
ID | Title | Version | Release Date | Edit Date |
20190815 | TCP SACK Panic - Kernel Vulnerability (CVE-2019-11477, CVE-2019-11478, CVE-2019-11479) | 1.2 | August 15, 2019 | January 08, 2020 |
20210108 | RUCKUS AP Arbitrary File Read Vulnerability | 1.0 | January 08, 2021 | January 08, 2021 |
20210114 | Ruckus AP LLDP Vulnerability (CVE-2015-8011, CVE-2015-8012) | 1.0 | January 14, 2021 | January 14, 2021 |
20210129 | AP / ZD CLI Passphrase Vulnerability | 1.0 | January 29, 2021 | January 29, 2021 |
20210409 | RUCKUS SmartZone Information Disclosure Vulnerability | 1.0 | April 09, 2021 | April 09, 2021 |
20210511 | RUCKUS AP Aggregation And Fragmentation Attacks Vulnerability (aka “FragAttacks”) | 1.1 | May 11, 2021 | October 15, 2021 |
20230404 | CVE-2022-47522: Framing Frames: Bypassing Wi-Fi Encryption by Manipulating Transmit Queues | 1.0 | April 04, 2023 | April 05, 2023 |
20231128 | CVE-2023-49225: RUCKUS AP Stored Cross-Site Scripting Vulnerability | 1.0 | November 29, 2023 | November 29, 2023 |
20240925 | RUCKUS AP Remote Code Execution Vulnerability | 1.2 | October 04, 2024 | October 11, 2024 |
20250710 | Reported vulnerabilities in RUCKUS SmartZone and RUCKUS Network Director: CVE-2025-44957, CVE-2025-44962 ... | 1.5 | July 10, 2025 | July 23, 2025 |
Technical Support Bulletins
TSB-2024-002 | TSB-2024-002_RUCKUS-License-Server-Host | 3.3 | 2024-05-08 | 2024-05-14 |
TSB-2024-007 | TSB 2024-007 - Upgrade Restriction from SmartZone 6.1.2 Patch-3 to SZ 7.0.0 or 7.1.0 | 1.2 | 2024-11-21 | 2025-01-07 |
