RUCKUS ICX 7850 Campus Switches
  • ICX-7850
    ICX-7850
Product Detail
Ruckus ICX 7850 Campus Switch
The Ruckus ICX 7850 Campus Switch is a high performance stackable core switch for next generation 100G campus. It delivers nonblocking line-rate performance on all ports concurrently, with a switching capacity of up to 6.4 Tbps. The ICX 7850 supports the next generation Ethernet speeds with 10/25 Gigabit Ethernet at the aggregation and 40/100 Gigabit Ethernet at the core to meet high volume of traffic driving from the edge into the core. It also supports a rich array of routing protocols and delivers a range of high-availability hardware and software features.
Model Name:
ICX-7850
Product Family:
RUCKUS ICX Switches
Recommended Software:
Stability Release:
Patches:
RUCKUS ICX FastIron 08.0.95n (GA) Software Release (.zip)
Notes:
Ruckus ICX software currently has two release types; Stability and Technology.
We recommend all customers utilize the Stability Release if it contains all needed features for your network. A Technology Release should only be used if your network requires new features not available in the Stability Release.
RUCKUS One (cloud) users: Please check the 'Version Management' page within your RUCKUS One GUI for your recommendation
The ICX 7850-48C requires FastIron 9.0+. We currently recommend the latest 10.0.10 patch for this specific sub-model.
Documents
Downloads
KB Articles
Forum Topics
Security Bulletins
Support Bulletins
Advanced Search
Working...Please wait
This is here to prevent you from accidentally submitting twice.
The page will automatically refresh.
Alert!!
Close
