Ruckus T301n
Product Detail
The T301n, a dual-band 802.11ac outdoor access point (AP), is designed explicitly for high density public venues such as airports, conventions centers, plazas & malls, and other dense urban environments.
Designed for easy installation within an ultra-lightweight and low profile enclosure, the T301n is ideal for venue owners and enterprises looking to quickly and economically deploy Wi-Fi in high-capacity environments. The T301n includes a narrow (30 degree) internal antenna.
- Model Name:
- T301n
- Product Family:
- EOL RUCKUS Products
- Recommended Software:
- Stability Release:
Unauthenticated TCP tunneling on Ruckus devices via SSH server process
An user authentication bypass vulnerability has been discovered during standard internal bug reporting procedures in some of the Ruckus devices. This vulnerability may permit an... (continued)
Ruckus Diagnostic Dashboard - Supported VM Platforms
A summary of the currently supported platforms
Ruckus Diagnostics Dashboard (RDD): System requirements
Summary of RDD system requirements based upon AP/switch numbers connected.
Ruckus Diagnostics Dashboard (RDD): Connecting an SCI to RDD
Summary on how to configure RDD to forward data to SCI.
How to Download Licenses from Ruckus Support Portal
How to add the SZ controller to Ruckus Diagnostic Dashboard(RDD)?
This article provides information on adding and configuring the SZ on RDD.
AP with default IP address can't establish Ruckus GRE tunnel
Number of DPSKs supported in RUCKUS Cloud per Tenant/account
This article briefs about total number DPSKs supported in RUCKUS Cloud
Do I need to declare downtime when uploading AP license file on Ruckus Controllers
Once the license file is uploaded on the controller, upgraded AP licenses should be available on the GUI.
SCG-200 AP Ruckus GRE tunnel not coming up after upgrade AP zone to 3.2.1
Prior to 3.2.1 Ruckus GRE tunnel uses UDP port 23233. In 3.2.1 TCP is now used
What is the tunnel offload feature on Ruckus APs running 3.6.2 and above version
Tunnel offload feature was introduced on SmartZone 3.6.2 version to enhance and improve the tunnel data throughput performance. Article explains basic details of this feature as it is... (continued)
Ruckus Diagnostics Dashboard: System hangs on "SMBus Host Controller not enabled"
When booting up Ruckus Diagnostics Dashboard for the first time, it show the "SMBus Host Controller not enabled" message, and seems to hang.
How does Ruckus use GRE
How does ZD/SCG employ GRE?
DHCPV4 Dynamic ARP inspection
AP sending high amount of DNS requests for vriot.ruckuswireless.com
This Article explains how to stop the excessive DNS requests which is sent by AP's for vriot.ruckuswireless.com when there is no IoT devices/controller in the network
DP tunnel core sends dummy DHCP requests to the DHCP server constantly
Data plane tunnel core sends a DHCP heartbeat to the DHCP server if the DHCP relay service is enabled in the DP Core Tunnel. These are 'dummy' heartbeats and will not always elicit a... (continued)
Why clients are failing to get an IP when connected to a tunneled SSID over Ruckus GRE on SZ cluster?
This article explains a scenario where clients failed to get an IP when connected to Tunneled WLAN over Ruckus GRE.
RUCKUS One re-login shows error
Login issues with RUCKUS One WebUI can usually be resolved by refreshing the session, re-typing the URL, or clearing your browser's cache and cookies. If these solutions don't work,... (continued)
Ruckus ICX 7650 PREM License
Ruckus ICX 7650 uses Self-Authenticated Upgrade (SAU) feature to enable license features.
Multicast support in Ruckus
Description of how Ruckus Access Points handle Multicast Traffic
How to find the Tenant ID from cloud portal?
This article explains where we could find the Tenant ID of cloud portal
Benefits of using SCG's tunnel mode
Use of RuckusGRE tunneling for SCG offers additional benefits.
Bypassing DNS entry for SZ AP discovery
How to manually configure an SZ AP to connect to a desired SZ controller when DNS server on network specified a different controller.
How to get diagnostics file of IOT controller
This article provides instructions on how to get the diagnostics file from IOT controller.
AP not establishing tunnel to data plane
This article explains how to troubleshoot an AP that is connecting to the vSZ controller but not forming a tunnel to a data plane.
How to Download ZD Entitlement File
Article provides step by step instructions on how to download an entitlement file. This is specially useful, if you have upgraded to 9.8.1 and above firmware. By downloading and... (continued)
SZ / SCG AP tunnel MTU Configuration location
This article describes where the tunnel MTU setting may be found on SZ / SCG
Authorized (Deny) status on a wireless client
This article explains the reason for Authorized (Deny) status on a connected client.
AP IP Change to dynamic setting from CLI
AP wan ip setting can be changed form SCG CLI and AP CLI.
How to downgrade SZ/SCG to previous version
How to downgrade SmartZone controller to a previous firmware version
Best practices for high density deployments
This article explains about some of the best practices to follow in a high density deployment
ICX7150-48ZP – Phone down on PoH ports
The first 16 ports of the ICX7150-48ZP are PoH. When connecting a phone (model: Grandstream GXP 2140), the phone gets powered, but the port never comes up. Same phone works completely... (continued)
SCG/SZ Tunnel keepalive timeout and retries
SCG control plane and data plane tunnels keepalive timers are configurable.
Configuration download by AP from ZD
AP downloads configuration from the controller
Downloading AP support info diagnostic file for SZ controlled Access Points
To assist customer NOC teams with determining which AP a client is connected to and how to download the AP support info if AP is connected or not connected.
How to migrate Access Point(AP) from RUCKUS One(R1) to RUCKUS SmartZone(SZ)
This guide provides a step-by-step process to migrate an AP from R1 to SZ. The process involves factory resetting the AP, upgrading it to a solo image, and then joining it to vSZ/SZ.
Activating RUCKUS One - RUCKUS End Customers (REC) License
This article provides instructions on how to activate RUCKUS One licenses. You can activate licenses through the RUCKUS Support Portal.
Managing Users in RUCKUS AI (formerly known as RUCKUS Analytics)
Article explains how to add internal and 3rdparty users in RUCKUS AI and manage them.
vSmartZone to RUCKUS One (Formerly RUCKUS Cloud) migration process
This article explains v/SmartZone controller managed Access points and Switches to RUCKUS One (Formerly RUCKUS Cloud) migration procedure.
ZoneDirector to RUCKUS One (Formerly RUCKUS Cloud) migration process
This article explains ZoneDirector controller managed Access Point to RUCKUS One (Formerly RUCKUS Cloud) migration procedure.
Do any Ruckus APs support DHCP/NAT feature?
Ruckus APs can provide DHCP/NAT features in Solo AP, wired Unleashed Master, and SZ 3.5+ zone Access Points.
Ruckus Mesh Max Hops and Loop Detection
Mesh algorithms are intelligent and dynamic, adjusting to conditions between last MAP and Root AP
Ruckus AP Certificate Refresh Flowchart
AP Certificate Refresh Flowchart for Existing AP Installs and New AP Deployments (after Nov 27, 2016)
Leap second impact on Ruckus equipment
This article describes the impact of applying a positive or negative leap second to Ruckus hardware.
Ruckus WDS with third party wireless bridge
Can any third party wireless bridges be used with Ruckus? Maybe, under certain conditions.
Ruckus Bonjour Gateway Deployment Guide
How to configure and troubleshoot Ruckus Bonjour Gateway in ZD and vSZ/SZ-100/SCG
LED Status on Ruckus Indoor APs
Details of LED status on Ruckus Indoor Zone Flex APs
Configuring LACP for R710 on Ruckus ICX 7450
Configuration guide for LACP on Ruckus ICX7450 switch for R710 (ACw2) model APs.
SNMP support on Ruckus One Wi-Fi controllers?
Ruckus already supports SNMP functionality in RUCKUS One controller
T301N on a zone director
I am running 8 -T301n ap's on a zone director 3025, but when i get 20 users on them the CPU in the unit shows it is running at 100% and the whole system bogs down, any suggestions
hi, Concurrent users are support to Ruckus 7372, T301s & T301n AP?
Please let me know how many concurrent users are support to Ruckus 7372, T301s & T301n Ap?
vSZ-D Ruckus GRE tunnel
SSID is not broadcasted when "Tunnel WLAN traffic through Ruckus GRE" is selected.
I don' t use NAT.
In the AP ZONE the tunnel selected is one created with Ruckus Tunnel mode GRE. On... (continued)
Ruckus AP Going Down
I have a R600 Unleashed and has been working fine for over a year. However now randomly it has been going down were it disconnects all the clients and goes into a loop of... (continued)
Ruckus Cloud website down?
Is the Ruckus Cloud website degraded for anyone else? All customers' devices are "disconnected" and website is in a read-only mode for me and my coworker.
Ruckus R710 dont get power from POE
Hi, All!I got second R710 on secondary market. I already have same model router - and it powers from Netgear POE+ switch without any issues during last 3 years....But when i try to... (continued)
Ruckus 7372
Consulta Compre un Ap Rukus y no puedo agregar al Zonadirector
Ruckus R610 AP
So I have a R610 indoor AP. I want to run this in stand alone mode, using a regular router behind it to do the DHCP server. Do I have to purchase the rights to make this a... (continued)
???2?r600?????ruckus
ð?????ruckus,?????,??:1.200??????????“????” ??????? 70??2.ruckus ???????ap ??????????? ???????2.4G?5.8G??????????ruckus ?????????3.????2?r600,????????,2?ap ... (continued)
Why Ruckus?
We are a public school district looking to do a complete overhaul of our wireless network. A bit over 725,000 square feet of indoor space, 4,300 students with nearly 1,400 students in... (continued)
Ruckus 7962 AP
Can the Ruckus Zoneflex 7962 AP operate in Standalone mode, or does it require a controller, like a WLC? I found a refurb at a great price, since I mainly wanted to... (continued)
Ruckus 7363 vs Ruckus R300
My company currently have the Ruckus 7363. We are looking to expand our office, I was wondering if the Ruckus R300 is a significant upgrade over the 7363 in term of interference... (continued)
Ruckus introduces Device Agnostic Networking (DAN)
http://www.ruckuswireless.com/press/r...
Community Update from Dan Rabinovitsj, Ruckus COO
This is a message to Ruckus partners and customers from Dan Rabinovitsj, Ruckus COO:
To Ruckus partners and customers from Dan Rabinovitsj, COO:
We recognize that many of you are... (continued)
Ruckus R720/R710/R610 Unleashed half speed download
Dear Ruckus, I have invested enough money to get fast and seamless internet on my APs. Not only did I recommend Ruckus Unleashed to many of my friends who wanted a fast and stable... (continued)
Urgent: ZD3400 upgraded firmware version 9.8.3.0.14 could not support wireless mesh, even T301n could not mesh wirelessly
Please sir urgent help needed to deliver a job.We have a customer using ZD3000, firmware version 9.4.2.0.29 controlling up to 300 units of (EOL) ZF7025 model APs.We were required to... (continued)
Ruckus r310 mesh
Does the R310 unleashed now support mesh networking? I saw a post here from 4 years ago saying no, but I saw the option in the unleashed setup so I’m a bit confused. I don’t want to... (continued)
Ruckus 7731 and P300
Hello everyone ,
I want to connect 3 School buildings by using wireless bridge (7731 OR P300) the distance between one and another about 100m ,also I want to use APs in the Schools'... (continued)
Ruckus WiSE Level 1
Hello, I appeared for the Ruckus WiSE Level 1 exam and passed with 83% score but cannot see my score or did not receive my certificate. It looks like I have not done... (continued)
Ruckus R720 Errors
Running a Ruckus R720 (106.0.0.99.1363) as a standalone unit and everything seems to be running fine from a WiFi perspective. That being said every 5 seconds or so I am seeing the... (continued)
Ruckus H320 DHCP/NAT
Hi,I am doing some testing with a H320, vSZ-H version 3.6.0.0.510, AP firmware 3.6.0.0.771, specifically the DHCP/NAT on the AP feature.I have it working fine over the WiFi, I... (continued)
RUCKUS ANALITYCS
How does an existing SmartZone integrate with Ruckus Analytics?
Ruckus ICX 7150 & R510
I just moved into a new home by Lennar and they have 1 ICX 7150 and 2 r510s installed in the house. I have ATT Fiber, ATT provides a modem/router which connects to the ICX 7150 and the... (continued)
Forti To Ruckus
Hello,i have Fortigate 100D with 4 forti AP that i think to upgrade to R510 unleashed.Today i have 2 SSID in seperate subnets that managed by Fortigate in gate mode and restrict with... (continued)
No Power ruckus r700
Hello, first of all i want to say i am a newbie at this chapter with routers but I have a problem. I have a ruckus r700 and whe. I plug The internet cable its not working, but The... (continued)
Dynamic PSK
Hi
Im new to ruckus, I wanted to know this Dynamic PSK feature. If the backend authentication do not have AD + Radius, how would this Dynamic PSK works? Let say I only implement PSK or... (continued)
Where can I find and download the Ruckus Radius dictionary?
Is there any dowloadable version of Radius dictionary for use with wireshark of RUCKUS controller decodes?
HI,How to download logs from Ruckus Zone director Model no.ZD1006.
HI we configure Syslog server for download logs but we need first login MAC id details instead of all entired logs. Please find the snapshot & suggest which we would select option for... (continued)
Ruckus 7962 wireless radio settings dont update after frimware 9.7.0.0.220
Hi recently i updated my AP to frimware "9.7.0.0.220" from "9.1.2.0.8" but after updating when i go to Configuration ->Radio 2.4G-> wireless 1 (tab) and enter my settings and click on... (continued)
does Ruckus support Capwap tunnel between AP and controller?
Does Ruckus support Capwap tunnel between AP and controller?
Will ruckus cloud respond to dynamic vlan assignments from a RADIUS server?
I'm using a trial ruckus cloud account. I think freeradius is returning the correct attributes on the accept but the authenticated user still ends up on vlan 1. I can't find any... (continued)
What does Ruckus mean specifically when it says it supports "Dynamic VLANs"?
Does this mean specifically support for 802.1x services or .1x like services?
Announcement: Ruckus Cloud WPA2 KRACK update starting tonight Nov 7, 2017 (PDT)!
Dear Ruckus Cloud Wi-Fi Customer,
We are rolling out a security patch to address KRACK vulnerabilities in WPA2. To learn more about KRACK and associated vulnerabilities,... (continued)
Cannot Download of Ruckus ICX FastIron 08.0.80d (GA) Release Notes
Good Morning,I cannot download the Ruckus ICX FastIron 08.0.80d (GA) Release NotesIt is set for "Premium Support Users."The irony is that the release itself like all others is... (continued)
Welcome to the Ruckus Diagnostic Dashboard (RDD) Forum page!
Ruckus Diagnostic Dashboard (RDD) is a lightweight tool that helps automate the troubleshooting and support process. RDD provides a single pane of glass view for Ruckus Support. Here... (continued)
RDD 1.8 is now GA for new customers to download from the Ruckus Support Site!
For existing RDD customers, there is no need to update to the new version. Over the next few... (continued)
Ruckus Cloud Outage - Network Down - APs and Licenses got deleted
Received alerts this morning at 4am PST all our licenses expired. Checked online and all our APs got deleted.Got on the phone with Ruckus and they say its a known outage.Anyone... (continued)
Ruckus Cloud down since 5:04 Mountain Standard time on Oct 23 2019. Anyone else?
Seems like Cloud WIFI is down for several hours. Client on site says internet is working (thankfully) but we have no access to our APs. Anyone else having this issue today?
Configuring a point to point bridge with 2 T301N AP's
I currently have an Extreme Networks wireless bridge in place but it continues to drop. My vendor consulted with his site survey guys and they suggested we use the T301N APs to... (continued)
Enable 2G/5G on Ruckus R700
Hi All,I want to configure my
Ruckus R700 Multimedia Hotzone Wireless AP, but can't find on the configuration 'using the web interface' 2G and 5G Wirelles. You can find in attachement... (continued)
Ruckus R500 for home AP???
This is my first experience with any Ruckus product. Without going into too much unnecessary detail, I will need wireless access to my home network soon and have acquired a R500... (continued)
Ruckus 7982 PoE Problem
I have 3 units of Ruckus Zoneflex 7982, but they dont work with the poe injector, only with the ac adapter, can you help me, please
No Ruckus unleashed app
Hello I am trying to download the Ruckus Unleashed app for IOS. However when I go to search for it it can’t be found.,
Ruckus P300 keep rebooting
We have Ruckus P300 and we facing issue with the AP, it's keep rebooting all the time, sometimes it go UP for one minute and it's down again, before it's working fine and no issue with... (continued)
Ruckus h510 update 200.9 error
I have ruckus unleashed setup (r710+h510) in my home. They have wired connection - no meshI try to upgrade to 200.9 firmware, but on h510 it cant download image with following... (continued)
Question Ruckus ZF 7361
????? ?????, ? ???? ? ?????? (I'm from Russia)
? ?????? ?? ????????? ????? ????? (and I speak in English very badly)
?????????? ??????????? ???????? ???????????? ?... (continued)
RADIUS SERVER WITH RUCKUS
what are the encryptions, keys and Radius server OS that supports the controller ZD 1100?
I need to configure radius for ZD1100 and i dont know what are its limitations or... (continued)
Ruckus CLI Airtime Stats
Hi,Can anyone tell me why the Airtime stats obtained via "get airtime <radio interface>" appear to go over 100%?Example output:get airtime wlan0 Raw counters: Total: 235... (continued)
ruckus vf2825 upgrade to 5.3
Hello,On the official page I saw new version for vf2825 - the version is 5.3. I follow the manual for upgrade, but the upgrade failed. Description of error: control file download... (continued)
ruckus without zone director
I am about to purchase a few ruckus aps. I was wondering if anyone has experience with using flexmaster with multiple aps and without zone director? I have read you can do that.... (continued)
Ruckus Radius and Smoothwall
I am a little confused with how to set this up. I have a Smoothwall box doing filtering and dishing out DHCP leases on VLAN 30. I have setup a VLAN SSID on 30 which works fine.... (continued)
ID | Title | Version | Release Date | Edit Date |
20200302 | Ruckus AP Image Upgrade Vulnerability | 1.0 | March 02, 2020 | March 02, 2020 |
20210511 | RUCKUS AP Aggregation And Fragmentation Attacks Vulnerability (aka “FragAttacks”) | 1.1 | May 11, 2021 | October 15, 2021 |
20230208 | CVE-2023-25717: RUCKUS AP Web Vulnerability (RCE/CSRF) | 1.2 | February 08, 2023 | May 18, 2023 |
20240925 | RUCKUS AP Remote Code Execution Vulnerability | 1.2 | October 04, 2024 | October 11, 2024 |
Technical Support Bulletins
