Product not found.
EOL RUCKUS Products
Ruckus SPoT
Ruckus SPoT™ Smart Positioning Technology the industry’s first cloud-based Smart Wi-Fi location-based services (LBS) user positioning technology suite that gives both carriers/service providers and enterprises the ability to deliver a wide-range of value added services that can help them increase their profitability while enhancing users’ online experiences. The most recent version of Cloud Hosted SPoT is 2.0.
FlexMaster
The Ruckus FlexMaster (FM) Management System is a fully-featured, intuitive, and complete, Linux-based managed service platform for configuration, fault detection, audit, performance management and optimization of hundreds of thousands of remote Smart Wi-Fi APs or Smart Wireless LANs (WLANs) from a single point. It provides a unique collection of automated and customized facilities not found in other management platforms such as an automated and customized super dashboard, trending reports and customized graphs, detailed client data for planning and troubleshooting and comprehensive events management.
Ruckus C110
ZoneFlex C110 Wave2 802.11ac (MU-Mimo) Wi-Fi AP with DOCSIS 3.0 backhaul support.
The ZoneFlex C110 is a Wave 2 802.11ac (MU-MIMO capable) Wi-Fi Access Point with support for DOCSIS 3.0 backhaul. The C110 comes in a convenient wall-plate form factor for easy installs.
C110 features Ruckus' patented BeamFlex+ adaptive antenna technology to deliver high-speed 802.11ac Wi-Fi in a low-profile design that can be discretely installed over a standard electrical junction box. C110, with a DOCSIS 3.0 backhaul, allows a range of wired and wireless services to be delivered in hotel guest rooms, student residences, and multi-dwelling units over existing coaxial cabling and, therefore, minimal additional capital expenditure.
C110 has an Ethernet switch with two 10/100Mbps Ethernet ports that can be used to connect a range of wired network devices such as IP telephones and networked minibars while simultaneously providing dual-band 802.11ac wireless LAN coverage.
The C110 is powered by an external 12V DC power supply. The C110 can be deployed as a standalone device or centrally managed by SmartZone or ZoneDirector management platforms.
Ruckus E510
The ZoneFlex™ E510 is a Wave 2 802.11ac (MU-MIMO-capable) Wi-Fi access point (AP) with a unique, diminutive two element enclosure which separates the RF components from the antenna module, is designed to address challenging RF conditions in an aesthetic manner.  The E510 is ideal for installation in stadiums, park benches, street furniture, light poles or on trains.
The E510 can be placed unobtrusively inside metal-shielded signage at a bus or train station, and within a vending machine and display kiosk.  The low profile antenna module can be located externally and linked to the RF module via weather proof cabling.
Ruckus Optics Tranceivers
Ruckus Optics Transceivers deliver Ethernet connectivity with guaranteed compatibility with Ruckus switches, full compliance with industry standards, and lifetime support, while satisfying a wide range of speed and distance requirements. The Ruckus Ethernet optics family include a wide rande of offerings designed to meed performance and scalability requirements of service providers, enterprise and small and medium business environments.
Ruckus Diagnostic Dashboard (RDD)
Ruckus Diagnostic Dashboard (RDD) is a Virtual Machine that helps automate the troubleshooting and support process. RDD provides a single pane of glass view for Ruckus Support. RDD monitors the health of SmartZone/virtualSmartZone, SCI, ZoneDirector, ICX Switches and can create technical support cases on your behalf when anomalies are detected.
Ruckus H320
The H320 is an entry-level Wave2 802.11ac (MU-MIMO-capable) Wi-Fi access point with integrated switch in a wall-plate form factor.
H320 features Ruckus' patented BeamFlex + adaptive antenna technology to deliver high-speed 802.11ac WiFi in a low-profile design that can be discretely installed over a standard electrical junction box.  H320 allows a range of wired & wireless services to be delivered in hotel guest rooms, student residences, and multi-dwelling unit swith just a single cable pull per room and eliminates the need for additional switches and power supplies.
H320 has dual-band concurrent 2x2:2 on 5GHz and 1x1:1 on 2.4GHz with MU-MIMO support.
With a 1Gbps Eth0 link to switched network, there are 2 Ethernet ports for in-room access, to connect a range of wired network devices such as IPtv set top boxes, IP telephones, or networked minibars while simultaneously providing dual band 802.11ac wireless LAN coverage.  The H320 itself may be powered via standard PoE (802.3af), and can be deployed as a standalone device or centrally managed by SmartZone, ZoneDirector, or FlexMaster management platforms.
Ruckus T310c
The T310c is an 802.11ac Wave2, 2x2:2 Outdoor AP with MU-MIMO.  It is a great fit when all that is desired is bare bones, basic outdoor WiFi coverage.  It has an Omni-directional internal antenna, perfect for outdoor deployments where WiFi access is needed like Stadiums, Smart cities, Large Public Venues, Campgrounds, Schools and other outdoor areas.  The AP is good for moderate temperature deployments, supporting temperatures down to -20C.
It can be powered using standard 802.3af/at PoE.  The T310c comes in a sleek, compact form factor - atypical for an outdoor AP.  The T310c can be deployed as standalone, or managed by ZoneDirector or SmartZone controllers.
Ruckus ICX 7250 Campus Switches
The Ruckus ICX 7250 Campus Switch delivers the performance, flexibility, and scalability required for enterprise Gigabit Ethernet (GbE) access deployment. It raises the bar with up to 8×10 GbE ports for uplinks or stacking and market-leading stacking density with up to 12 switches (576×1 GbE) per stack. In addition, the Ruckus ICX 7250 combines enterprise-class features, manageability, performance, and reliability with the flexibility, costeffectiveness, and “pay as you grow” scalability of a stackable solution.
Brocade ICX 6650 Campus Switches
The Brocade ICX 6650 Switch easily moves high-performance application data, but its benefits go far beyond speed. You get a flexible solution that lets you pay as your grow. Customizable security features and design efficiencies that help keep your TCO low.
RUCKUS ICX Target Path Selection Guide
Click here to access the most recent RUCKUS ICX Target Path Selection Guide
Ruckus T310d
The T310d is an 802.11ac Wave 2, 2x2:2 Outdoor AP with MU-MIMO.  The T310d is the most advanced Outdoor AP in it's class - enabling multiple use cases of outdoor deployments that are not possible with any other AP.  It is an omni-directional internal antenna AP, perfect for outdoor deployments where WiFi access is needed like Stadiums, Smart cities, Large Public Venues, Campgrounds, Schools and other outdoor areas.  The AP supports temperatures down to -40C, making it a good fit for extreme weather deployments where WiFi is still critical.
It can be powered in 2 ways: through standard PoE (802.3af) and for the first time, through DC power.  The DC power input ensures that Meshed outdoor T310d APs are not powered off an unreliable power grid - ensuring that the WiFi outdoor mesh network can continue to function even during grid power outages.
Additionally, the T310d comes with a USB port - perfect for supporting all manner of IoT technologies - both today, and any new technologies that come in the future.  The T310d enables multiple different use cases, yet retains a sleek, compact form factor - atypical for an outdoor AP.  The T310d can be deployed as standalone, or managed by ZoneDirector or SmartZone controllers.
SmartCell Gateway 200 (SCG200)
The SmartCell™ Gateway (SCG) 200 represents the first in a new category of scalable and versatile WLAN controllers with support for 3GPP compatible WLAN gateway functionality. It has been designed to eliminate the difficulties operators are experiencing with building and managing large-scale Wi-Fi RANs and integrating them into the mobile packet core. The latter is required for a truly scalable heterogeneous network (HetNet) deployment. Capabilities include:
Massively Scalable WLAN Controller
Support for WLAN Gateway Functionality per 3GPP Standards
Integrated Element Management System Support
Support for Hotspot 2.0 functionality
Ruckus H510
The ZoneFlex™ H510 is a Wave 2 802.11ac (MU-MIMO-capable) Wi-Fi access point with integrated switch in a wall-plate form factor.
H510 features Ruckus' patented BeamFlex + adaptive antenna technology to deliver high-speed 802.11ac WiFi in a low-profile design that can be discretely installed over a standard electrical junction box.  H510 allows a range of wired & wireless services to be delivered in hotel guest rooms, student residences, and multi-dwelling units with just a single cable pull per room and eliminates the need for additional switches and power supplies.
Equipped with four Ethernet ports for in-room access, the ZoneFlex H510 can be used to connect a range of wired network devices such as IPtv set top boxes, IP telephones, or networked minibars while simultaneously providing dual band 802.11ac wireelss LAN coverage.  An IEEE 802.3af-compliant Power-over-Ethernet (PoE) port on the H510 allows devices such as IP telephones to be powered directly from the wall switch.  The H510 itself may be powered via standard PoE or a DC power adapter.  The H510 can be deployed as a standalone device or centrally managed by SmartZone, ZoneDirector, or FlexMaster management platforms.
Ruckus ICX 6610 Campus Switches
The Ruckus ICX 6610 Switch delivers smoothly streaming video, crisp and clear audio, and click-it-and-see-it response time.  These high-quality user experiences fuel productivity, but require a very fast, ultra-reliable campus network.  That's exactly what the Ruckus ICX 6610 campus switch provides in a highly economical design.
Ruckus T310n
The T310n is an ultr-specialized outdoor access point (AP) meant for extremely targeted deployments, when focusing the WiFi signal is of paramount importance.  The T310n enables use cases that no other outdoor AP can do while meeting strict customer SLAs.  It is unique in that there are no comparable APs of its class.
The T310n is a dual-band 802.11ac Wave 2 outdoor AP which includes a narrow (30 degree) internal antenna, enabling a focused beam.  This is critical in deployments like stadiums, where the AP might be deployed far away from the user, or in challenging RF environments like warehouses - to get WiFi down long aisles.  Having a focused beam enables meeting customer SLAs that omni or sector APs cannot hope to meet.  Additionally, it also has a USB port and a unique DC power option that enables multiple use cases like IoT support and Mesh without reliance on a power grid.
Designed for easy installation within an ultra-lightweight and low profile enclosure, the T310n is ideal for venue owners and enterprises looking to quickly and economically deploy WiFi in specialized or challenging high-capacity environments.
ZoneDirector 1000
ZoneDirector 1000 product family
NOTE: ZoneDirector software upgrade is available only to the Premium Support or Software Upgrade Support customers with valid login credentials. If you are a Premium Support or Software Upgrade Support Customer, you can create a login credential Here.
Please read the intended version Release Notes before deploying any new ZoneDirector software.
Ruckus ICX 6430 and 6450 Campus Switches
These manageable, entry-level switches support advanced routing, and include premium ICX 6610 features, in mixed stack configurations, giving you unmatched availability and economics.
Ruckus T310s
The T310s is a specialized outdoor access point (AP) meant for more targeted deployments, when focusing the Wi-Fi signal is of paramount importance.  Unlike other sectorized APs of its class, T310s is not restricted to just a sector AP, but provides a platform for multiple different use cases in one box.
The T310s is a dual-band 802.11ac Wave 2 outdoor AP which includes a wide (120 degree) internal antenna, enabling a focused beam when it makes little sense to waste WiFi in an Omni deployment, such as blanketing a public park that is surrounded by apartments, or a stadium.
Additionally, it also has a USB port and unique DC power option that enables multiple use cases like IoT support and Mesh without reliance on a power grid.
Designed for easy installation within an ultra-lightweight and low profile enclosure, the T310s is ideal for venue owners and enterprises looking to quickly and economically deploy focused WiFi in high-capacity envrionments.
ZoneDirector 1100
ZoneDirector 1100 Product Family
Please read the Release Notes before deploying any new ZoneDirector software.
Customers with 7962/7762/7025 model AP recommended release is 9.8.3.0.58, found Here.
Brocade FastIron CX Series Switches
Brocade FastIron CX Series Switches:  FCX-624 and FCX-648
The Brocade® FCX Series of switches provides performance, scalability, and flexibility required for enterprise campus and data center networks. Designed for wire-speed and non-blocking performance, the Brocade FCX Series includes 24- and 48-port models, in both Power over Ethernet (PoE) and non-PoE versions.
Ruckus M510
The ZoneFlex™ M510 is a Wave 2 802.11ac (MU-MIMO-capable) Wi-Fi access point (AP) designed to leverage LTE networks as a backhaul and connect wirelessly back to any network without the need for an Ethernet cable connection.
Because of the LTE backhaul capability, the M510 addresses multiple deployment scenarios not previously served, including mobile "in-vehicle" WiFi (mobile AP), rapid Wi-Fi deployment and pop-up retail or first-responders and temporary Wi-Fi deployments at construction site.  M510's LTE backhaul can serve as failover or redundancy for the WAN connectivity.  M510 is managed only by SmartZone.
ZoneDirector 1200
With simplicity and ease of use in mind, the RuckusZoneDirector 1200 is purpose-built to address the gap between standalone, feature-deficient access points (APs) that must be individually managed and the costly, complex high-end enterprise systems that are overkill for most small business environments.
The Ruckus ZoneDirector 1200 can be deployed and operated by non-wireless experts and installed quickly and easily. Any organization with limited IT staff and budget can create a robust and secure multimedia WLAN in a matter of minutes.
This controller is focused on small to medium enterprise business, which scales up to 150 AP’s, 4,000 client devices, and 256 WLANs.  The ZD 1200 works with the ZoneFlex AP’s to deliver a highly reliable and easy to manage Wi-Fi network. The pay as you grow licensing system allows you to start with a standard license for 5 AP’s and grow to a maximum of 150 AP’s with a granularity of one AP license.
Looking for ZD5000, ZD3000, ZD1100 or ZD1000 resources?  Please check EOL Products.
SmartZone 100 (SZ-100)
SmartZone™ 100 (SZ-100) is the most scalable, resilient, and highest performing Wireless LAN controller within the Ruckus family of WLAN controllers for enterprises around the world. It manages up to 1,024 ZoneFlex Smart Wi-Fi access points, 2,000 WLANs, and 25,000 clients per device. Its unique SmartZone architecture allows the SZ-100 to be deployed in a 3+1 Active-Active cluster. With Active-Active clustering all members (up to 4) of a cluster will actively manage APs in the network, providing enhanced resiliency for high availability requirements. With clustering, the SZ-100 can manage up to 3,000 APs and 60,000 clients.
Smart licensing allows customers to manage all licensing needs online at https://support.ruckuswireless.com. With Smart licensing, customers have the ability to buy and assign licenses at a granular level down to 1 (one) AP license.
Brocade FastIron SX Series Switches
Brocade FastIron SX Series Switches:  FSX-800 and SX-1600
The Brocade FastIron SX series of Layer2/3 switches provide a superior scalable foundation for improved operational efficiency and faster response to business opportunities today and into the future, extending control from the network edge to the backbone with intelligent network services, including superior Quality of Service (QoS), predictable performance, advanced security, comprehensive management, and integrated resiliency.
Ruckus M510-JP
Because of the LTE backhaul capability, the M510 addresses multiple deployment scenarios not previously served, including mobile "in-vehicle" WiFi (mobile AP), rapid Wi-Fi deployment and pop-up retail or first-responders and temporary Wi-Fi deployments at construction site.  M510's LTE backhaul can serve as failover or redundancy for the WAN connectivity.  M510 is managed only by SmartZone.  The M510-JP model is for use in the country of Japan only.
ZoneDirector 3000
ZoneDirector 3000 Product Family
Please read the Release Notes before deploying any new ZoneDirector software to be sure your current AP models are all supported.
Brocade FastIron Edge X Series Switches
Brocade FastIron Edge X Series Switches:  FESX424, FESX624, FESX424-POE, FESX448, FESX648, FESX424HF, and FESX624HF
The Brocade® FastIron Edge X Series offer a diverse range of switches that meet Layer 2/Layer 3 edge, aggregation, or small-network backbone-connectivity requirements with intelligent network services, including superior quality of service (QoS), predictable performance, advanced security, comprehensive management, and integrated resiliency. It is the ideal networking platform to deliver 10 Gigabit Ethernet.
SmartZone 100-D (SZ100-D)
The SmartZone™ Data Plane appliance (SZ100-D) is a wireless LAN data plane appliance, that comes in physical form factor as a family of two products, first with 1Gbps and second with 10Gbps throughput support. Made to work seamlessly with Ruckus SmartZone network controllers, the SmartZone Data Plane appliance enables secure tunneled WLANs from Ruckus APs while minimizing CAPEX spending and maximizing Wi-Fi deployment flexibility and scale.
SZ100-D appliance benefits businesses that have leaner IT departments with limited virtualization expertise or that wish to further simplify deployments. Operators, ISPs and large enterprises can deploy the SZ100-D in a centralized data center with SmartZone network controllers, or at specific venues in a distributed topology. In addition, organizations have the flexibility to deploy SZ100-D at each of the tenant locations based on their requirements.
The Data Plane appliance brings multiple high value features, such as:
  - High performance DHCP-server
  - NAT (Network Address Translation)
  - L3 Roaming
  - Flexi-VPN
Ruckus R320
The R320 is an Indoor 2x2:2 802.11ac Wave2 (MU-MIMO-capable) Wi-Fi access point.
The Ruckus R320 delivers consistent, reliable 802.11ac Wave 2 dual-band wireless networking at an affordable price, and offers up to 867Mbps throughput on 802.11a/n/ac 5GHz, and up to 300Mpbs throughput in 802.11b/g/n 2.4GHz range. It has a single Gigabit Ethernet port and can be powered by 802.3af PoE or 12V DC power supply.
The R320 features the patented Ruckus performance optimization and interference mitigation technologies found in our premier access points, to deliver superior user experiences at extended ranges. But it provides them in an ultra-compact form factor built for small and midsize businesses and low to mid-density hotspot environments.
ZoneDirector 5000
ZoneDirector 5000 Product Family
Ruckus T610
The T610 delivers blazingly fast connectivity for high-density outdoor deployments, with combined radio data rates of 2.5Gbps and the density-handling ability to match.  Patented BeamFlex+ technology rejects interference amd improves signal quality for any device, anywhere.  Included MU-MIMO technology maximizes network efficiency, reducing bottlenecks and enhancing user experience.  Smart Mesh accelerates time-to-deployment and eliminates the cost associated with Running Ethernet cabling between multiple access points in the network.  The T610 can be used with any Ruckus control and management platform - appliance, virtual or cloud-managed.  That means as your business needs change, your architecture - and your APs - can change with you.
The T610 is designed for high-density deployments in which dozens of clients need guaranteed high throughput.  Smart Cities providing city wide wireless connectivity for: municipal Wi-Fi, untilities and smart sensors for IoT applications are ideal use cases for the T610.  The T610 is for customers that want premium wireless performance and don't have specialized backhaul interface needs (like fiber or coaxial cable).
Brocade FastIron WS Series Switches
Brocade FastIron WS Series Switches: FWS624, FWS624-EPREM, FWS624-POE, FWS624G, FWS624G-EPREM, FWS624G-POE, FWS648, FWS648-EPREM, FWS648-POE, FWS648G, FWS648G-EPREM, FWS648G-POE.
The Brocade® FastIron Workgroup Switch (WS) Series is a complete line of one rack unit (1RU) enterprise-class Layer 2/3 switches. The FastIron WS Series extends the Brocade edge-to-core networking portfolio by providing intelligent edge switches designed for Small and Medium Businesses (SMBs), branch offices, and distributed enterprises—without compromising performance and reliability.
Ruckus C500
Ruckus Ruckus C500 High Performance 802.11ac Mid-
Range Smart Wi-Fi Access Point with embedded DOCSIS
3.0 Cable Modem. Engineered from the ground up to
provide a single box solution to support multi-service
operator's indoor SMB and HotSpot opportunities, the
C500 combines patented adaptive antenna array with
interference mitigation and predictable performance at
extended ranges, with up to 4dB of BeamFlex gain and
up to 10dB of interference mitigation.
Antenna dual-polarization delivers consistent performance
for hand-held devices movement and rotation. Integrating a
Cable Modem in a sleek and low-profile design means fewer
components to install and is ideal for servicing a variety of
medium density enterprise and HotSpot environments,
including SMBs, hotels, schools, retail outlets, and branch
offices. The C500 requires SmartZone (SCG, SZ-100, vSZ)
controller management.
Ruckus R510
The ZoneFlex R510 brings cutting edge 802.11ac Wave 2 to the mid-tier segment.  It improves aggregate network throughput and benefits both Wave 2 & non-Wave 2 clients.   It combines Ruckus patented technologies and best-in-class design with the next generation of 802.11ac features to deliver outstanding Wi-Fi performance and reliability.  It future proofs the customer for emerging Internet of Things (IoT) technologies.
With throughput capacities of 300Mbps (2.4GHz) and 867 Mbps (5GHz), the ZoneFlex R510 brings cutting edge Wave 2 technology for the mid-tier segment.  802.11ac Multi-User MIMO (MU-MIMO) support allows the R510 to simultaneously transmit to multiple client devices, drastically improving airtime efficiency, overall throughput, and availability.
ZoneFlex R510 is purpose-built for medium density, high performance and interference-laden environments such as schools, universities, small-medium businesses, hotels, MDUs and conference centers.
Ruckus T710
The ZoneFlex T710 is the industry's first and highest performing 802.11ac Wave 2 Outdoor AP.  The T710 combined Ruckus patented technologies and best-in-class industrial grade design with next generation of 802.11ac features to deliver industry-leading Wi-Fi performance, reliability and coverage for challenging high density outdoor deployments.  With throughput capacities of 800Mbps (2.4GHz) and 1733 Mbps(5GHz), the ZoneFlex T710 supports the highest available thoughtput for Wi-Fi clients.  802.11ac Multi-User MIMO (MU-MIMO) support allows the T710 to simultaneously transmit to multiple client devices, drastically improving airtime efficiency, overall throughput, and availability.  The T710 is designed to support multiple backhaul scenarios like Ethernet (with Link Aggregation between the 2 Ethernet ports supported to boost data rates) andFiber.
The T710 is ideal for deployment in dynamic outdoor environments with highest density utilization and interference, like public outdoor hotspots, smart cities, outdoor enterprise and schools,where support for hight client densities and/or data intensive streaming multimedia applications (like HD IPvideo) is imperative.
Brocade TurboIron 24X Series Switches
Brocade TurboIron 24X Series Switches: TI-24X.
The Brocade® 24X Switch is a compact, high-performance, highavailability, and high-density 10 Gigabit Ethernet (GbE) solution that meets mission critical data center and High-Performance Computing (HPC) requirements.
Ruckus H500
The Ruckus H500 is a converged wired and wireless wall switch featuring Ruckus BeamFlex+ smart antenna technology to deliver high-speed 802.11ac Wi-Fi in an ultra-sleek, low-profile design that can be quickly and discretely installed in a standard wall junction box. Ideal for offering converged services in hotel guest rooms, student residences, and MDUs, the Ruckus H500 provides an easy way to offer multiple connections into a single room without multiple cables.  Equipped with four Ethernet ports for in-room access, the ZoneFlex H500 can be used to connect a range of wired network devices such as IPTV set top boxes, IP telephones, or networked minibars. An IEEE 802.3af-compliant Power-over-Ethernet (PoE) port on the H500 allows devices such as IP telephones to be powered directly from the wall switch. The H500 itself may be powered via PoE or DC power adapter.
Ruckus T710s
The ZoneFlex T710s the 120-degree Sector coverage version of the T710 - industry's first and highest performing 802.11ac Wave 2 Outdoor AP.  The T710 combined Ruckus patented technologies and best-in-class industrial grade design with next generation of 802.11ac features to deliver industry-leading Wi-Fi performance, reliability and coverage for challenging high density outdoor deployments.  With throughput capacities of 800Mbps (2.4GHz) and 1733 Mbps(5GHz), the ZoneFlex T710s supports the highest available thoughtput for Wi-Fi clients.  802.11ac Multi-User MIMO (MU-MIMO) support allows the T710s to simultaneously transmit to multiple client devices, drastically improving airtime efficiency, overall throughput, and availability.  The T710s is designed to support multiple backhaul scenarios like Ethernet (with Link Aggregation between the 2 Ethernet ports supported to boost data rates) andFiber.
The T710 is ideal for deployment in dynamic outdoor environments where directional (120-degree sector) coverage is required.
Brocade Mobility RFS9510 Controller
Brocade Mobility RFS9510 Controller: BR-RFS9000-RFS9510
The Brocade Mobility™ RFS9510 Enterprise NC Controller lets you centrally administer networks up to 10,240 WLAN access points geographically dispersed over numerous telecommuter and small or medium sized enterprise locations.
Ruckus R300
The Ruckus R300 is an entry-level indoor Access Point offering best in class performance. The R300 features dual 802.11n radios (2.4 and 5 GHz) in a 2x2:2 MIMO configuration, yielding up to 600 Mbps of physical layer throughput. A single Gigabit Ethernet port and can be powered via 802.3af PoE or by a separate
12VDC power accessory. The R300 sports a low-profile, minimalist industrial design and is extremely compact in size, measuring 13 x 13 x 2.8 cm (5.1 x.5.1 x 1.1 inches).
Brocade Mobility RFS7000 Controller
Brocade Mobility RFS7000 Controller: BR-RFS7000
The Brocade Mobility RFS7000 Controller provides centralized Wireless LAN (WLAN) configuration and management by coalescing a network “intelligence” previously spread across physically distributed access points.
Ruckus R310
The ZoneFlex R310 is the industry’s lowest cost enterprise class 802.11ac access point. The R310 has dual radios (2.4GHz & 5GHz) which are capable of concurrent operation. It is a 2x2:2 stream access point, offering up to 867Mbps of physical layer throughput in the 802.11 a/n/ac 5GHz range, with an additional 300Mbps physical layer throughput in the 802.11 b/g/n 2.4 GHz range. It has a single Gigabit Ethernet port and can be powered by 802.3af PoE or a 12V DC power supply. The R310 has a compact form factor (13.8cm x 13.5cm x 3.3cm) is extremely helpful in easy installation, and enables the power of 802.11ac literally in the palm of your hand.
It is perfect for low client density deployments such as coffee shops, convenience stores and other brick & mortar establishments, where cutting edge WiFi is necessary, but there is only a lean IT staff to manage the network. The R310 is a perfect entry level enterprise class 802.11ac access point that delivers maximum value at minimal cost.
Ruckus R610
The ZoneFlex R610 delivers blazing performance, with data rates up to 1900 Mbps and the density-handling ability to match.  Patented BeamFlex+ technology rejects interference and improves signal quality for any device, anywhere.  Included MU-MIMO technology maximizes network efficiency, reducing bottlenecks and enhancing user experience.
The R610 is a great fit for deployments in high-density enviornments in which dozens of clients need guaranteed high throughput.  K-12 schools offering online digital learning with 30+ kids per classroom and university lecture halls serving concurrent HD video streams to hundreds of student devices are perfect use cases for the r610.
The R610 can be used with any Ruckus control and management platform - appliance, virtual or cloud-managed.  That means that as your business needs change, your architecture - and your APs - can change with you.
Brocade Mobility RFS6000 Controller
Brocade Mobility RFS6000 Controller: BR-RFS6000
The Brocade Mobility RFS6000 Controller provides centralized Wireless LAN (WLAN) configuration and management by coalescing a network “intelligence” previously spread across physically distributed access points.
Ruckus R500
The ZoneFlex R500 is the industry’s best-performing 2x2 802.11ac indoor WLAN access point, combining Ruckus-patented RF technologies with the new IEEE 802.11ac standard to provide outstanding WiFi performance.
The R500 features dual radios, capable of concurrent operation.  It features a 5 GHz 802.11a/n/ac radio in a 2x2:2 spatial stream configuration, capable of physical layer rates of up to 867 Mbps. A 2.4GHz 802.11b/g/n radio in a 2x2:2 spatial stream configuration offers an additional 300 Mbps of physical layer throughput. Ruckus’ ZoneFlex R500 is an ideal access point for medium client density enterprise and hotspot environments including SMBs, schools, hotels, branch offices and retail outlets.
Brocade Mobility RFS4000 Controller
Brocade Mobility RFS4000 Controller: BR-RFS4000
The Brocade Mobility RFS4000 Controller provides centralized Wireless LAN (WLAN) configuration and management by coalescing a network “intelligence” previously spread across physically distributed access points.
Ruckus T811-CM
The Ruckus T811-CM outdoor Access Point delivers the industry's highest performing 802.11ac Wave2 4x4:4 Wi-Fi in a lightweight, strand-mounted form factor that easily integrates with existing HFC networks. It features patented Ruckus technology to extend wireless range and reliability, combined with an integrated DOCSIS 3.1 cable modem. Available with an omnidirectional antenna, the T811-CM delivers consistent, reliable data access in a wide range of high-density environments.
Ruckus R600
The ZoneFlex R600 is a 3x3 802.11ac WLAN access point featuring performance-enhancing, Ruckus-patented RF technologies available at a compelling price point.  The R600 is ideal for medium- to high-density mobile device wireless networks. It is a power-efficient access point, capable of operating with full functionality on standard (802.3af) PoE.  This keeps total cost of ownership of the R600 low by eliminating the need to upgrade to more expensive PoE+ switch infrastructure.  The R600 features dual radios, capable of concurrent operation.  It features a 5 GHz802.11a/n/ac radio in a 3x3:3 spatial stream configuration, capable of physical layer rates of up to 1300 Mbps. A 2.4 GHz 802.11b/g/n radio in a 3x3:3 spatial stream configuration offers an additional 450 Mbps of physical layer throughput.
Ruckus R710
The ZoneFlex R710 is industry’s highest performance 802.11ac Wave 2 access point.  It combines Ruckus patented technologies and best-in-class design with the next generation of 802.11ac features to deliver outstanding Wi-Fi performance and reliability.
With throughput capacities of 800 Mbps (2.4GHz) and 1733 Mbps (5GHz), the ZoneFlex R710 supports the highest available throughput for Wi-Fi clients. 802.11ac Multi-User MIMO (MU-MIMO) support allows the R710 to simultaneously transmit tomultiple client devices, drastically improving airtime efficiency, overall throughput, and availability.
ZoneFlex R710 is purpose-built for high-capacity, high performance and interference-laden environments such as schools, universities, public venues, hotels, and conference centers.
Brocade Mobility 1220 Access Point
Brocade Mobility 1220 Access Point:  BR-AP1220
The Brocade Mobility™ 1220 Access Point, a component of the Brocade wireless controller system, links wireless 802.11a/b/g/n devices to the controller, enabling the growth of your wireless network with a cost effective alternative to standard access points.
RUCKUS T811-CM (Non-SFP)
The RUCKUS T811-CM (Non-SFP) outdoor Access Point delivers the industry's highest performing 802.11ac Wave2 4x4:4 Wi-Fi in a lightweight, strand-mounted form factor that easily integrates with existing HFC networks. It features patented RUCKUS technology to extend wireless range and reliability, combined with an integrated DOCSIS 3.1 cable modem. Available with an omnidirectional antenna, the T811-CM (Non-SFP) AP delivers consistent, reliable data access in a wide range of high-density environments.
Ruckus R700
The Ruckus R700 ensures the most reliable connectivity within challenging and ever-changing RF environments. With BeamFlex+, the Ruckus R700 is capable of delivering 6 dB of signal-to-interference-plus-noise (SINR) improvement and up to 15 dB of interference mitigation over other APs. The R700 simultaneously supports spatial multiplexing and BeamFlex+ to deliver the best price/performance of any three-stream 802.11ac AP.
Brocade Mobility 1240 Access Point
Brocade Mobility 1240 Access Point:  BR-AP1240
The Brocade Mobility™ 1240 Access Point is a premium, Enterprise class, Access Point positioned at the top of Brocade’s Access Point product line. The Mobility 1240 Access Point is a plenum rated, 3x3:3 802.11n Access Point utilizing two 802.11a/b/g/n radios.
Ruckus R720
The ZoneFlex R720 is a new dual-band concurrent 4x4 802.11ac Wave 2 Access Point capable of 160 MHz and 80+80 MHz channelization, designed for high density indoor applications.  The R720 features one 10/100/1000 Etherenet port, and one 100/1000/2500 Ethernet port that supports 802.3af and 802.3at Power Over Ethernet (PoE), and a USB port for IoT applications.
Ruckus Q910
The Ruckus Q910 is an outdoor pole, wall, or strand-mounted LTE Access Point for CBRS.  Q910 offers the highest CBRS capacity available in a fully-integrated, rugged outdoor package.  Q910 features 1W of RF power, 1GB Ethernet, PoE+ input and integrated BeamFlex antennas.  Q910 is managed only by Ruckus LTE AP Management.
Ruckus T300
The ZoneFlex T300, a dual-band 802.11ac outdoor access point (AP), is designed explicitly for high density public venues such as airports, conventions centers, plazas & malls, and other dense urban environments.
Designed for easy installation within an ultra-lightweight and low profile enclosure, the T300 is ideal for venue owners and enterprises looking to quickly and economically deploy Wi-Fi in high-capacity environments.
Ruckus P300
Deploy Ruckus P300 802.11ac Point to Point/Multipoint bridges to extend wireless coverage between remote locations or enable broadband services in places not reachable before in an affordable way. With the P300, service providers can reliably provide best in class wireless backhaul performance at ranges up to 12 kilometers.
Brocade Mobility 6511 Wallplate Access Point
Brocade Mobility 6511 Wallplate Access Point:  BR-AP6511
The Brocade Mobility™ 6511 Wallplate Access Point integrates a dual-band 802.11a/b/g/n AP and switched Fast Ethernet connectivity into a sleek design that is fast and easy to deploy on any wall surface or structured wiring telecom box using the existing CAT 5/6 cabling.
Ruckus R730
The Ruckus R730 is a new dual-band concurrent 12 stream 802.11ax-Ready Access Point, capable of delivering 4.8Gbps with 8x8:8 5GHz radio and 1.148Gbps with a 2.4GHz radio.
The R730 is designed for high density, high performance applications, and has on-board BLE & Zigbee radios for IOT Applications.  The R730 supports a 5Gbps PoE_in Ethernet interface that can operate with uPOE, PoH, and 802.3at power, and has an additional 1Gbps Ethernet interface and a USB port.
Ruckus T301n
The T301n, a dual-band 802.11ac outdoor access point (AP), is designed explicitly for high density public venues such as airports, conventions centers, plazas & malls, and other dense urban environments.
Designed for easy installation within an ultra-lightweight and low profile enclosure, the T301n is ideal for venue owners and enterprises looking to quickly and economically deploy Wi-Fi in high-capacity environments. The T301n includes a narrow (30 degree) internal antenna.
Brocade Mobility 650 Access Point
Brocade Mobility 650 Access Point:  BR-AP650
The Brocade Mobility™ 650 Access Point, a component of the Brocade wireless controller system, links wireless 802.11a/b/g/n devices to the controller, enabling the growth of your wireless network with a cost effective alternative to standard access points.
Ruckus T301s
The T301s, a dual-band 802.11ac outdoor access point (AP), is designed explicitly for high density public venues such as airports, conventions centers, plazas & malls, and other dense urban environments.
Designed for easy installation within an ultra-lightweight and low profile enclosure, the T301s is ideal for venue owners and enterprises looking to quickly and economically deploy Wi-Fi in high-capacity environments. The T301s includes a wide (120 degrees) internal antenna.
Brocade Mobility 7131 Access Point
Brocade Mobility 7131 Access Point:  BR-AP7131
The Brocade Mobility™ 7131 Access Point, a component of the Brocade wireless controller system, links wireless 802.11a/b/g/n devices to the controller, enabling the growth of your wireless network with a cost effective alternative to standard access points.  The 7131N Access Point includes a 3rd, WIPs dedicated antenna.
Ruckus T504
The Ruckus ZoneFlex T504 is a purpose-build strand mounted access point that combines dual-band 802.11ac with an integrated cable modem.  With patented adaptive antenna technology, the T504 delivers unprecedented range and reliability for multiple system cable operators (MSOs).
Managed by SmartZone controllers, the Ruckus T504 is lightweight and can be easily installed and integrated with the cable operator's network.  It leverages existing cable assets, including mounting, power, backhaul and customer service systems to quickly and easily extend wireless services to cable operator's customers.
Ruckus 7781-CM
Ruckus 7781-CM Dual Band 802.11n Outdoor Access Point with DOCSIS 3.0 Cable Modem.
For actual Cable Modem firmware, Access it here
Ruckus Q410
The Ruckus Q410 is an indoor, ceiling or wall-mounted LTE Access Point for CBRS.  Q410 can be deployed by itself or plugged into existing Ruckus Wi-Fi access points such as the R510, R610, and R720 for the ultimate in upgradeability and future-proofing.  Q410 features 1/2W of RF power, 1GB Ethernet, PoE+ input and integrated BeamFlex antennas.  Q410 is managed only by Ruckus LTE AP Management.
Ruckus 7982
The Industry's Highest Capacity, Highest Performing Three-stream Ruckus 7982 802.11n Smart Wi-Fi Access Point for Carriers and Enterprises
Ruckus Q710
The Ruckus Q710 is an indoor, ceiling or wall-mounted LTE Access Point for CBRS.  Q710 offers the highest CBRS capacity available in an attractive, Enterprise-friendly design.  Q710 features 1W of RF power, the maximum indoor power allowed by FCC rules, 1GB Ethernet, PoE+ input and integrated BeamFlex antennas.  Q710 is managed only by Ruckus LTE AP Management.
Ruckus 7441
The ZF7441
is a purpose built AP designed to enable Wi-Fi services onto in-building
wireless coax systems, commonly called DAS or Distributed Antenna
Systems.
Ruckus 7352
The Ruckus 7352 is amid-range 802.11n 2x2:2 2.4GHz (single-band) access point, capable ofdelivering up to 300 Mbps of physical layer performance.  The Ruckus 7352 is optimized for high client density enterprise and hotspot environments where 5 GHz mesh or access is not required.  It may be powered by 802.3af PoE or accessory power adapter, is physically discrete and unobtrusive due to its small size and minimalist industrial design, and can be mounted to hard walls or ceilings and acoustical drop ceilings.
Ruckus 7372
The next generation Ruckus 7372 mid-range 802.11n 2x2:2 dual-band 2.4GHz and 5GHz concurrent access points are designed for high density mobile device environments with bandwidth hungry and latency sensitive applications such as Voice and Video over Wi-Fi
Ruckus 7055
Multiservice 802.11n dual band concurrent 2 stream Wired/Wireless wall switch The Ruckus 7055 is the industry’s first dual-band dual-concurrent wall mounted wired switch and wireless wall switch designed for next generation wireless. The Ruckus 7055 features integrated 2.4GHz and 5GHZ concurrent 802.11n WLAN radios, five wired Ethernet ports, PoE ouput, and a passthrough port for devices such as digital phones that require native access to a PBX system. Designed with hotels and multi-dwelling units in mind, the Ruckus 7055 is easy to mount to an electrical junction box and has a sleek and low-profile form factor.
SmartCell 8800 Outdoor AP
The Ruckus SmartCell 8800 Series represents a completely new class of outdoor access point (AP) technology designed specifically to address the capacity and siting challenges mobile operators face in deploying HetNets in dense urban environments.
Ruckus 7761-CM
The first high performance strand-mounted 802.11n Smart Wi-Fi access point with cable modem.
Ruckus 7782
  • Carrier-class 2.4/5GHz 802.11n Access Point with an integrated 30º narrow beam antenna for unprecedented performance in high-density applications
Ruckus 7731
Use Ruckus 7731 802.11n Point to Point/Multipoint bridges to extend wireless coverage between remote locations or enable broadband services in places not reachable before with the 7731 wireless backhaul.
Smart Access Management (SAMs)
Smart Access Management service (SAMs) is a hosted public cloud Wi-Fi service. SAMs brings together best-in-class Wi-Fi with cloud computing to simplify the provisioning,management and monetization of public Wi-Fi access.
ZonePlanner
Ruckus ZonePlanner (ZP) is a Wi-Fi RF simulation tool which integrates Ruckus Wireless Access Point antenna patterns with the industry-leading AirMagnet planning software.  ZonePlanner is ideal for designing Ruckus AP deployments and estimating Wi-Fi coverage before the physical installation.  With ZonePlanner, network managers can more easily and accurately plan, design, deploy and manage Ruckus Smart WLAN networks in any indoor environment. The latest antenna patterns are provided in this knowledge base article link.
ZonePlanner has been replaced by the web-based Yagna Wi-Fi Planner.
Create an account: https://ruckus.yagnaiq.com/Login/
FAQs:  https://partners.ruckuswireless.com/system/files/yagna-faq.pdf
Working...Please wait
This is here to prevent you from accidentally submitting twice.
The page will automatically refresh.
Alert!!
Close
